DynaGlide
- May 16, 2017
Crazyraceguy said:DynaGlide said:Do you guys with both setups use the Zeta for carcass construction or stick to the Domino?
Going to be making some base cabinets soon and was toying with using tenso and screws.
For me, it depends on the application. For frameless, I generally use Dominos. For face frame, again it depends. Sometimes, I make the face frame attach with Tenso.
I am far more likely to use either of the Lamellos for things other than simple cabinet construction. They are great for assemblies like mantles and such.
As I see it, Dominos are essentially an alignment device that require glue (or some other alternative) to hold things together.
Lamellos are an attachment device by themselves, but the alignment factor is not nearly as robust. That's why I use both. Well, that and the fact that the Lamellos are way too wide for building face frames. They are great for holding them on though.
[member=58857]Crazyraceguy[/member]
Since you're one of the guys who worked production/cabinet shop I'd like your opinion. I'm starting on 5 base cabinets and 2 tall uppers (sitting on counter top, secured to wall). Frameless construction.
The last time I built cabinets was for my office ~3-4 years ago. Frameless and I used domino and screws. I didn't own the Zeta. Now I own the Zeta and the Domino.
All of the base cabinets are pre finished maple and only require edge banding. The uppers are Combi-core and will be sprayed.
So what'd be your economical/practical approach? Tenso doesn't work until final assembly and even then I'd likely use screws in addition to them. I could do Bisco's for mockup and measurements for doors/drawers. Clamex would be pretty expensive just for a dry fit when they're ultimately going to get screwed together.
This is all being built in my garage and moved inside the house for install. No transportation issues or issues getting fully assembled boxes to their installation space. I could see committing to the Zeta fasteners for the uppers which get sprayed to help things along.
To me the Zeta makes the most sense for attaching a face frame to frameless. I'm wanting to find a reason to use it for this project but keep going back to I should just use domino's and screws to dry fit and assemble the boxes.
