Impact driver recommendation
Hi!
It sounds like what the OP is looking for is a "higher RPM" "Spinner" that doesn't hurt the wrist if it's by accident not stopped on time. Hence the 3/8 impact. Higher RPM and if not stopped on time it won't break your wrist when operated with one hand.
Personally I think that if you're looking to buy 30 units, at least 2 - 3 batteries per unit and probably even a charger each - that's something that most representatives from the afore mentioned manufacturers/importers of Panasonic, Hilti i.e. will gladly come out to demonstrate what they have. I can't speak for Hilti US, but their fleet service around here is top notch and the tools, honestly, they are what they are.
"Problems" I see: No one is really going to like the Idea of a 3/8" (or even some 1/2" compact type) driving 30 or 32mm sockets - even if their main job is only going to be "free-spinning" a bolt . This is going to be an issue especially when looking for service/repair/replacement because of premature wear.
But like I said, I really think it's best discussed with actual sale reps of those "usual suspects" like Panasonic, Hilti - maybe Snap-On, but I don't know if they do industrial stuff directly in the US - As I definitely wouldn't want to be hanging by one franchisee in your type of work/ overall setting. And I don't know if it would be the right tool for the job anyway - I love my 3/8" Snap-On for what it is and it serves me well, but I'm not even close to your usage cycles, compared to what you're looking for, what I do is pathetic.
I think if I was in your situation, I'd call Hilti and hear what they say face to face on location.
Kind regards,
Oliver
six-point socket II said:
Hi!
Kind regards,
Oliver
. The 1/2” Compact Impacts will easily handle a standard length 30 or 32mm socket. Especially if you need their higher RPM operating speed over a Cordless Tool with no huge impact blows setting the final torque since that will be handled by another tool.
I recommend Astro-Pneumatic’s Onyx model since A-P will tell you they weren’t trying to match the much higher quoted Torque Ratings of their Competitors models. But instead, a more reliable tool in the Compact class, needing less downtime or repairs.  The Direction Control and Power Setting valve is on the Rear of the Tool, making it easier to reach and adjust in my opinion compared to what seems to be a common design with the power adjustment around the Tools’ Trigger on other Compact Impacts.
I’ve seen THAT design more problematic out here in the field since it seems to be a bit delicate.
Hi!
Just to clarify, I wasn't referring to your post about the compact air tools, when I made my comment in regards to 1/2" compact (battery powered) impacts.
Kind regards,
Oliver
Hi!
Kind regards,
Oliver
  Not a problem Oliver.... [thumbs up]
