Holmz said:Personally I would get a ETS EC 150-5mm to pair with your finish sander.
(... or a 1/2-sheet, an LS130, an RO or a belt sander)
But the ergonomics are better with the EC.
. I thought so too as I was buying my EC 125...... I already own an EC 150/5... [cool]Huxleywood said:The ETS EC 150/5 indeed makes an excellent companion to a ETS 125
Dovetail65 said:Come on, its a fact that ETS 125 is a dog and anyone that says it has enough power never tried another sander with it side by side, its impossible.
And to say someone would not be better off with an EC 125 over an ets 125, well that tells me they never tried those two side by side.
Even for the people that don't like the EC there is no way they can say it's not better by a huge margin over an ETS 125.
Opinions may vary over the ETS 150's and EC 150's(I like the EC and the ETS 150's), but the older ETS 125 is just a weak, poor value sander, period. Many publications will back me up on this.
Makita, Bosch and DeWalt all make far better sanders at the ETS 125 price point, heck those manufacturers 99.00 sanders I feel are better than the Festool ETS 125 at near double the cost.
I have used every sander I talk about, I don't just say, well my 125 has enough power and then write off an EC as not needed. I try and use the darn things before I make recommendations. Once you try a quality took only then do you know whether you need it or not.
I reviewed the EC Sander soon after it was released and up for sale. I , and others, noted that it's not going to sit flat on a workpiece with a hose attached, unlike the older ETS Sander. But, I also pointed out that once your hand is on the sander, it's a moot point since the sander is so easy to keep flat.musserwood said:Someone brought up the old ETS being top heavy. I actually think the EC is top heavy in comparison. If you take the old ETS connected to a hose from a boom arm and put it on your work, it will sit flat by itself. The EC will not - the weight of the hose causes it to tilt. Id actually rather have some weight to help with the sanding. The EC might be more aggressive, which would explain its, in my opinion, excessive vibration and pull. We tend to stick with what works. Figured the EC would be an improvement or same when we bought, but not worse. Again, these are our requirements. If I was doing weekend woodworking projects I might like a more aggressive sander. We run most of our stuff through a wide belt sander first, so only need the ETS for the final sanding. All our frames and doors come out of wide belt very smooth and clean, so it's just to take things down to 180 or 220. But again, our requirements - you aren't going to see a wide belt in most home shops as they are three phase 30 hp motors - so you might want the pep to smooth out your glue ups etc. I just read somewhere else in this forum that they are releasing the old ETS again at the end of the summer, once they get all the Pro-5s out. This, I think tells you something - that Festool knows the EC is a bit of a dog, otherwise why have two 5" RO disc sanders?
