- Jan 22, 2007
Alex said:Untidy Shop said:[size=13pt]
Alex I generally agree with your last point, but audiences are a key factor here. Mention 4x8, 8x4 to someone who works/sells wood and they know it is a wood, plaster or cement based sheet product, even in a metric country where it is 2400mm x1200mm.
However mention 8x4 to a photographer and they may know it is a 8X4 inch sheet of photographic paper or plate film.
I am talking in general here, please don't go splitting it out how every individual's situation is different. My example is perfectly valid in Rick's case.
Just like [member=19439]Paul G[/member] I understand using metric is not practical for you if you're the only one using it.
A conversion from one system to another is not something a country does overnight, it takes at least 2 generations. Your generation will not be the one to do it. But your kids or grand children will get better used to it because thanks to internet exposure, they will grow up with it.
Actually Alex, it's not valid. You are confusing a "Name" with a "Dimension". It may be called 4x8, but when working out dimensions it is typically inches. What makes it worse is Untidy's example of 2400x1200, because that one implies dimensions, but the actual size is not 2400x1200.
Yesterday there was a comment about how products would have to be redesigned for different units of measure. This is a major misconception, which is quite evident in the 2400x1200 example. You don't design something based on its units, and you don't change the design if you change units. The plywood is still the same size, but we/they put different numbers to it. The only exception to this non-conversion is with machine screws, where diameters and pitches differ between the two.
