Isn't it about time U.S. went metric?
Untidy Shop said:
Kev said:
I like those and for the life of me I can't find a supplier of something similar in Oz .. you'd think it would be easy!
[size=13pt]Mmmmm, let me think?  [eek]
Oh yes, Home Hardware, Bunnings, Masters ....  You know Kev, those big Australian Hardware Chains that you drive past on the way to Northern Abrasives.  [big grin]
Look for the displays of Prestige Cabinet Connecters.
http://www.itwproline.com.au/default.aspx?FolderID=219
[size=8pt][member=13058]Kev[/member]
Sadly I do everything I can to avoid sending my hard earned through corporations that are owned publicly. With some things you just can't avoid it.
I have a whole bunch of those bolts buried somewhere among the debris of my shop.  I think I got them from rockler many moons ago.
They called them "Barrel Bolts".  They came with a little round barrel shaped nut on the end.  I got a bunch of them when I was building a workbench and was planning to make a bunk bed for a friend. They are handy for anywhere you might need to retighten along the way.  also, anywhere you need a bolt buried completely within the project As RMW said, they are handy for a lot of shop stuff. I have seen them listed elsewhere as "Connector Bolts".
Tinker
[member=8712]Richard/RMW[/member]
I need less than 12 of the nickel 1/4-20 bolts in approximately 20mm length.  Do you know of a source where I can buy them in short lengths in small quantities?  The woodworking stores do have them, but not that short.
I took your earlier suggestion and googled, but the results all seem to be manufacturers or distributors that sell in quantities of 1,000.
Thanks, Mike A.
Thanks, Mike A.
[member=30413]mike_aa[/member] Stafast sells in small quantities, I ordered a mixture of sized in qty of 10-50 no problem:
http://shop.stafast.com/
Not sure if the have a minimum but the quantity was not an issue.
RMW
Thanks!  I added 10 (the minimum number) to the cart to see what happened and it took it fine.  Only $1.19 for ten of them.  No mention that I see of a minimum order dollar amount, but I think I'll look at other stuff I might need anyway and put it all on one order.
Thanks, Mike A.
