gimmesomeshelter
- Oct 4, 2013
[big grin]
Do you have any other products on the works?
Cheers,
Paul
Cheers,
Paul
Kev said:Thoughts on ideal length of positioned ...
To my way of thinking, the flexibility of moving this new plate towards and away from the tool using the MFT holes means you can use a modest length positioner and minimise any potential deflection. Does anyone have thoughts on this? I suppose there's a factor of "you can have it, but you don't have to use it" when it comes to the length of the positioners ...I suppose I'm torn between a 17 and a 25 [unsure]
Thoughts?
Thoughts?
 ) then the 25 is probably a bit better. Be warned, the 25 on the MFT all the way out, will take over the whole table!
) then the 25 is probably a bit better. Be warned, the 25 on the MFT all the way out, will take over the whole table!Reiska said:Well, I ordered the 25" model last night specifically to be able to utilize the whole table width when using it with my CMS-TS55 insert as a table saw. We'll see how much full width cutting use it will get.
I'm not really expecting to be able to use the MFT as a table while using it as a saw/router table though.
Reiska said:Yes and since I'm going to go through customs anyway I ordered the parallel guide set as well. ;-)
Reiska said:I'll begin with 24" T-trackPlus for the parallel guides and see where to go from there.
Kev said:Reiska said:I'll begin with 24" T-trackPlus for the parallel guides and see where to go from there.
Hmm, maybe I should have grabbed them too [sad]
Reiska, I'm probably going to hold off on the positioner till you get your 25, please let me know then whether you would have been happier with the 17.
... well, they're both in a shopping basket and I'm hovering over the checkout button [embarassed]
deeka said:the precision plate on the precision dogs website is listed as out of stock. Does anyone know when it will be available again? Is there an alternative, if they stop manufacturing the plate?
thanks
suds said:Wondered how this setup was working for you fellas? How does this plate work better than a simple mounting to a 3/4" board with holes for Qwas Dogs? I know I'm missing something here.
