jmbfestool
Yeah it has legs and the ramps are stored below. The legs stop it from tipping so you can drive onto the trailer.
Like I have done with my fork
I was torn between I for Williams or. Brian James.Alan m said:nice trailer there jmb.
is there legs on the back or am i imagining it
jmbfestool said:Improved brakes and suspension.
I for Williams still use old leaf springs also are known for brakes to seize up if left standing for a while.
Tinker said:JMB, I don't think i like the design of that trailer. I use my ancient trailer (1987) tandem axle every day during the landscaping season.
I think all of those tailgate and sidegate semi hidden catches will eventually haunt you. i have seen the pics of your loader/forklift machine and i know you are not bashful about working in muddy conditions. You will need to clean those catches often. Every day if moving your machine in wet weather.
i had a truck body with removable posts between drop down sides. I had to remove bolts and put back in when i wanted flat bed. That could get to be a real PITA, especially in winter freezing temps and ice conditions. I would never get another body like that.
The tie down points are a terrific dirt collector system. Give me floppy rings and solid welded bars along the side rails. I have ratchet type straps that i can hook up anywhere on my trailer. When I was having it built, i told my fabricator it was impossible for him to put too many tiedown pionts. as his assistant was welding all of those rings and bars, he constantly complained about my sanity. I have not spent the time to try to finally figure out how to post pics here on the FOG, but I have not seen too many trailers, if any, with as many tiedown points as mine.
I don't understand the suspension. From your pic, it looks like the only flex is tire pressure. Is it torsion suspension? That is probably better than leaf springs, but I am not familliar with torsion on a trailer. Those axles do look tough. I have 3750# axles (each axle)and I have already had to replace after first 15 years. I think mine are way over speced for the loads i carry. i don't think i have ever had more than 6000# gross, but the axles have broken down. I guess they get tired after day in and day out use. Your axles look to be much heavier. But I like leaf spring suspension.
Over all, if you can keep mud and other debris out of all those catches, and avoid denting or bending (that complicates hooking and unhooking those hidden catches) the tail gate and side gates, the trailer should give you satisfaction for many moons. Of course, if you get tired of it, you could always put pontoons on it and send it across the pond to my place. :
Tinker
Tinker said:I have never seen torsion suspension on small trailers.
For my brakes, i have a solar charged system to keep the electric brakes charged. I was told it was good for at least five years. I park the truck/trailer in the sun. so far, aftr five years, the system seems to still be working fine. It is much better than the old brake system which depended entirely on the truck alternator/battery.
Another point i do like on the trailer is completely anodized aluminum. i am sure it is very light weight in comparison to mine. I have boxes welded into the sides and over the A-frame with steel fenders strong enough to use as a work bench in emergencies.
Total weight [scared] 2500#s. I bet JMB's trailer doesn't weight half that. I approve of that.
Tinker
jmbfestool said:Tinker said:JMB, I don't think i like the design of that trailer. I use my ancient trailer (1987) tandem axle every day during the landscaping season.
Tinker
That's another pointer about the tiedown points i forgot to mention which you did mention. Mud!
Brian James are holes with metal flaps so mud just falls through to the ground so don't fill up. Down side to just holes with rings you can thread through a rope you can't with these hole tiedown points.
No I'm not shy getting muddy or using something to its fullest! But I do look after my tools!
I do not intend to damage my trailer nor do I intend to get the catches covered in mud. Yes the flat bed will get muddy dirty scratches but I can't see why I would ever manage getting the catches covered in mudd/dirt
jmbfestool said:Tinker said:I have never seen torsion suspension on small trailers.
Tinker
Gross Load 3500kg. Weight of trailer 720kg. So I can carry 2780kg
Tinker said:What does that green toy weigh. If it were me, i would be loading it so more of the weight is over both of the trailer axles.
don't even ask how I know it is a good idea. :-X
Tinker
Tom Bellemare said:I've never towed a dual-axle trailer but have thousands of miles towing boats on single-axle trailers. Are their characteristics similar?
With a single-axle, I found that if the tongue weight was too light, they wanted to fishtail and the heavier the tongue, within reason, the more stable the trailer.
