I agree, plus the traditional way should allow for a bit of movement, domino's sound like a lot of unnecessary work to me.galwaydude18 said:I'd keep mitering, gluing and pinning as usual. Nothing worse than butt joints in skirting
jmbfestool said:I never mitre. If you want to see a joint then mitre away.
If you dont want to see the joints then butt joints are the way forward.
If its small skirting i just butt joint and use PU construct. Once sanded you wont see the joint
If its tall skirting like the ones you will be fitting i stick a couple of dominos in it
I dont know why people still do mitres for straight joints.
Its a pain in the arse for one and it does not make for a better joint.
Locks14 said:jmbfestool said:I never mitre. If you want to see a joint then mitre away.
The reasons for the mitre include:
1) a diagonal cut creates more surface area for glue.
2) cutting through the grain at an angle in certain species creates a smoother cut will less coarse open pores in the surface so less chance of the glue being sucked up into the grain and starving the joint.
3) you can nail through a diagonal joint to pin the join, which you can't do with a straight cut.
JNComplete said:I'm with Jim B. I've installed miles of large or tall base using butt joints and biscuits. The alternative I believe you are referring to is what we call a scarf joint. Problem I find or tell my guys, you need to land it on a stud. Plus half the time, your scarf joint ends up slightly proud( long)requiring sanding or worse.
Of course, with a stain grade joint, I'd be more apt to go with the scarf joint.
With paint grade, you can biscuit or domino both pieces at your chop saw, and with a longer piece or two u can afford to cut them slightly longer and snap it all intonolace. Super tight joint!
andyman said:Used the jmb method today worked great with biscuits
