Acrobat
- Jun 30, 2008
Excuse me if this has been answered before, I did a search that resulted only in the larger 50 to 36 hose sizes. My question is...
I have a 36mm hose fitted on the kapex which has a large fitting on its other end, that fits into my Midi vac IF I take the vacs 27mm hose and its elbow fitting out completely, and whilst that works it's a pain having to completely unwind and remove the vac hose and then fit the larger hose from the Kapex into the lid opening on the midi vac. So, can I get a reducing sleeve that will take the end of the kapex's hose and fit it to the 27mm hose from the midi vac? i.e join the two hoses together?
Incidently, I assume this added length of hoses will reduce the vac suction somewhat, but as long as it works it's quicker and easier for me as I then wheel the vac away and use it immediately with the sander (so a pain to have to re-fit the elbow and hose end etc in each time).
thanks
thanks
