semenza
My understanding is that .... they are working on it.
GarryMartin said:With respect, that's not what Tyler said.
There's a world of difference between causation and correlation, and what Tyler (and Festool) are looking for is a larger sample set than the one they might have access to at the moment so that they can test their assumptions in relation to something that could be a complete red herring. That seems like an inherently sensible thing to do.
It wasn't an admission that there is a problem with "rapid cuts in relatively thin pieces of wood" if that's how you read it.
bobfog said:Which in corporate speak is as good as an admission.
You may want to include what blade is in useTylerC said:We have heard back from the Festool HQ in Germany about this topic. They have taken a deeper look into the number of repairs and the repair causes. All Kapex-related comments on the FOG were also reviewed.
The findings:
While the number of repairs on the Kapex is slightly higher than expected, it is not a systematic problem. Roughly a third of the repairs are related to the motor, and we are currently looking into the root causes. Despite the fact that this is not an unusual concentration, we take this topic very serious because we understand the trouble every non-functioning tool causes for our customers.
Right now it seems the failures are related to a specific usage pattern (rapid cuts in relatively thin pieces of wood opposed to slower cuts in big beams). To verify this, we would like to ask you for your help.
Here is how you can help: If you have experienced a motor burnout or feel the Kapex has served you less than a fair amount of time, please send an email to kapex[member=6061]festool[/member].com with the following information:
[list type=decimal]
[*]Your contact information (name, e-mail, phone number)
[*]What type of work do you mostly use your Kapex for? The more information you can provide, the better. We are especially interested to find out what type of material you are cutting, understand what type of cuts you are mainly doing (rapid cuts in thin material oo more big beams etc.), and how often you are using your saw.
[*]Information on the type of failure and what has been done to fix the failure (repairs after what time etc.)
[*]Do you use a Kapex 110/120 volt model or a 220/240 volt model?
[*]Purchase date or machine numbers if available
[/list]
We appreciate you are taking the time to send us this information. It will help to better understand what leads to these issues.
