Guys,
Just wanted to start a new thread as the discussion on this started on another topic (sort of). I'm a little surprised to see no response from Festool on this issue as it is a known problem and people seem to be out there floundering around trying to get their new $1,300 purchase to work as intended.
There are two ways that the miter gauge can scrape and be a problem.
1) The Miter lock does not completely release and drags on the BOTTOM of the miter gauge. Festool's fix is to send out the bottom cam plate with different thickness (depth) of detents. This appears to open up the clearance on the bottom if this is your issue.
2) The tab that hangs down from the moving miter table rubs on the top outside edge of the Miter Gauge. Festools answer for this is the remove the Cam Plate, Miter Handle, and scrape the paint off the tab so that it allows a little more clearance between that tab and the miter gauge. This fix may have worked in a few cases.
Either one of these problems can cause some scrape marks and burring on the miter gauge that can just keep causing a user problems. You will need to sand and smooth out the Miter gauge.
My saw has now suffered from both of these issues and scraping the paint and several layers of metal off the tab have not solved the rubbing issue. It still scrapes pretty hard. I will get my Replacement Kapex tomorrow but don't have my hope that it's going to be ok either. I thought I just had a bad one but after seeing the other messages I know that's not the case now.
It's time to stop thinking this is just because of the tight tolerances and that taking off some paint will fix it. I like others didn't have a problem with any contact at first. Things were working well on the first day until about 11AM and then I couldn't hardly turn the table. All contact at this point was on the bottom of the Miter Gauge. I got the replacement plate the next day (Thanks Festool) and it Worked! That is until about 11AM that day and then the Miter table started locking up again. I thought it was the same thing but after taking off the miter handle and plate noticed that I now had severe contact at the top of the plate. I took it all apart and scraped off Paint and metal about 4 times and couldn't get it to stop! I'm now awaiting a replacement saw. Something on the Miter Table is moving. Unless this design is allowing temperature to really change these tolerances something else is amiss. I don't believe it has anything to do with paint on a tab. Why does it not rub and then after use start GRINDING and BINDING?
Christian? Shane? Can either of you give us users/customers a little information on this issue? I am concerned and have invested a lot of time, money, emotion on this.
Thanks,
Chris...
Thanks,
Chris...
