Kapex Table Sticking
Grev
I apologize if this has been covered, but thought I'd throw it out there for anyone who has the same problem.  The issue was my table was beginning to stick, and became somewhat difficult to rotate.  I saw there was a nut I could probably loosen to remove the upper portion of the saw and clean the hidden surfaces, but first I decided to tip over and spray a little "molykote" in the underneath casting.  I saw a couple square openings in the casting .. so I gave it a try.  I then set the saw upright and rotated left and right several times and problem was solved.  If you have the same problem, you might try this before taking your saw apart.  Not sure if this is "Festool" approved, but it worked for me with minimal effort/time.
