HarveyWildes
- May 3, 2016
Woodpeckers has announced their latest OTT - Rabbet Gauges.
http://www.woodpeck.com/rabbet-gaug...70123803&_bta_c=9nbp26x8jmy9bqpdfbbx8ssrs2eli
Seriously? if you only do rabbets in 12 pre-decided depths/widths, and never use undersized plywood, these may be what you need for marking them out.
The text on the Woodpeckers site mentions sizes that are not standard, and then mentions the technique of sneaking up on cuts, but doesn't seem to think that you will still need to sneak up on non-standard sizes if you own these gauges. "With a marking tool of this quality and precision, there'll be no need for guessing or trial and error cuts." It also seems to be confusing marking precision with cutting precision. While marking precision is useful, cutting precision is what makes the joint. After all, I'm brilliant at marking out for hand-cut dovetails.
