Let's make some Drawers
Great tutorial, Overtime!  I gotta try me some of those hidden slides.
Another word of advice for those who may try the adjustable drawer front inserts.  Drill them offset from each other.  I've split oak fronts down the middle when hammering the second one home.  They act like wedges and man, they fit tightly in the holes.  And I sure would never try them right on a glue line.
The faces are still off the left side (not for long)
Good time for photo op
Back of drawer notches were done on the table saw with stacked dado.  ;D  Table saws are still legal and are not yet on the endangered species list ;)
Here I got a little too close to the side
Yea I knew I was gonna give em a photo op but the results are just as is no special treatment.
But I have done the back saw cut deal,  then chop out.
Then there's always the Festivus way (stole that from Stoolman) and thanks for that vote a while back  8) , like so and would yield same results.
  didn't think about this till later but table saw still rules.
So after you get those nice clean notches taken care of you will need to drill those holes for the tabs at the backs of the drawer runners. They have got to be in the right spot. Turns out the tabs are connected to the grey plastic cam deals and that's what lifts or lowers the drawer back off the runner. The specs are given but as mentioned earlier this drilling jig makes it a no brainer  ;D
It fits in the notch and bottoms out on the inside of the side and flat against the back
Yea those nylon inserts. When I said that they won't come out , I went thru hell trying to get one out. Drilling holes on each side of it being carefull not to drill all the way through the face. Pulling and drilling. Those things are tough. Looks like I'm in good company  :)
  I think the old school way of drilling an over sized hole through the front of drawer works just as well.
fshanno - I was going for a modern kind of minimal look and to keep the cost down by using less solid stock. And ended up with ply for the final design. I was concerned with all the negative aspects you mentioned and gave some serious thought to going this route. Slab doors and drawer fronts with continuous grain when possible. How hard could it be ?
  I thought -  well I can get square cuts so that's a start. Furniture grade ply for slabs and drawers is all new to me.
Getting quality ply is the best way to great results. I used to wonder about the good ply with the MDF core or veneer. I did not use it on this project and have never used any yet but I have to think that it would help greatly with the flatness and warping issue.
I used mostly 3/4" teak ply and some solid for some trim and shelves and the toe kick.  The cabinets are sitting on a separate platform to give a toe kick look.
I did have some minor trouble with warping. And I had a hell of a time with finishing, more like a bump that was the most troublesome of the project. But I learned allot. For me building the project is almost always easier than the finishing.
I'll start a thread in the projects section with more on those details soon.
I have seen very similar stuff like the kerf design.
  The stuff I saw looked like they used ApplePly by State Industries then just plain ole formica or wilsonart p-lam. Clean edges with a bull nose.  I thing some good Baltic birch would work just fine and if you ran into a void at an edge most likely it would be small and bondo would be just fine. Give that extra utilitarian, industrial, loft like look at no extra charge  ;D
Dude,  that is some beautiful work.  I'd like to see more pics of the cabinet adjacent the toilet as well.  Maybe with the doors open.  Nice post!
Those big doors are made of plywood?  Not from my suppliers.  Not unless I'm going for that slightly curved look.
Good design, good execution.  I like that bathroom.
