Life without a thickness planer
Good Morning,
On planers in general, and handling shorter boards, we've discussed this here before, and some of us have posted ways to safely deal with shorter boards.
Here's a post from Jesse Cloud on a jig for handling shorter boards:http://festoolownersgroup.com/index.php?topic=2398.msg25266#msg25266
Here's a post about a simple jig I use in my shop for handling shorter boards:http://festoolownersgroup.com/index.php?topic=696.msg6120#msg6120
There are others as well.  Search is your friend!
Matthew
Problem with used planers,damaged rollers,worn or chipped cutters,or the treads for up down all gummed up....Picking the thing up is like buying a used car,its going to need a good tuneup especially if the last guy using it was a little careless.
I recommend buying new if funds permit it First
I found a picture of one like mine on the internet. Mine is in better shape though. I knew it was heavy, but they said it weighed 196 pounds.
Tage Frid shows how to flatten a board with a router sled.  There's a good explanation, with photos, in one of his books.
Even if you've already bought a lunchbox planer, this would be a good method for jointing one face of a board.
I haven't read the responses so I apologize if this has been covered.
I used a jointer plane up until very recently (just got a Planer/Jointer combo machine). If you have or plan on getting an MFT 3 you could thickness boards that way although it is quite  a bit of work and requires a knowledge oh sharpening.
Another option may be the Festool HL 850 which would double as a jointer. With some a bit of practice you could probably flatten and thickness boards with this. Buy the jointer fence and joint with it as well.
Dan Clermont
