Lost techniques for dealing with the heat.
Packard
Before the invention of air conditioning, many tricks were used to defeat the heat.  Many of those tricks are long-lost because A.C. Has been in public buildings since 1950 - 1960.  In residential homes a few years later.
I am listing a few, prompted by the current heat wave (expected to last 8 - 10 days, and exceptionally long time for a heat wave in our area.
Other techniques to try (or not to try) are invited.
O.K., first lost technique:  Painting roofs with white wash.  This had to be done yearly just as summer approached.  The white reflected the heat and kept the building cooler.  Rain and general wear, would wash away the white wash, so that it would go back to absorbing heat in the winter.
Lost technique #2. It works, but a mixed blessing.  They would place sprinklers on the roof and they would set the water pressure so that the water evaporated just as it hit the surface of the roof.  There would be no puddling.
And here is the mixed part of that blessing:  It would cause condensation on the ceiling of the building so, even if it did not “rain” on the occupants, it would cause the Timbers to rot or the steel beams to rust.
Cold water on a hot day:  I had a course woven water bag.  When you first filled it, it would leak like crazy.  About 10 minutes later all the fibers had swollen and it was “waterproof” again.  It cooled by evaporation.  If you slung it outside of your car, it would feel ice cold when you drank it.  Only fairly cool otherwise.
The bit about the almost wet roof, my dad told me about.  I never saw it myself.
The white washed roof I read about in a Farmers’ Almanac compilation.
There are listings online for the water bags.
images
Land Rover used to offer a “Tropic Roof for their trucks.  This was a second skin over the first with about a 2” spacing between the roofs.  If you sat in the sun, the air beneath the top skin would super heat, and flow out the sides and effectively you were sitting in the shade.
A Land Rover with a tropic roof:
And this I just read about (a play on the white-washed roof).  Scientists have developed a white paint that reflects 98.1% of all light hitting it.  (Most white paints reflect 80 to 90 percent.) It presumably will last longer than white wash.
https://grist.org/buildings/scientists-look-for-the-holy-grail-the-whitest-paint-ever/
- Trees for shade around the house
- Wearing clothes rather than basically nothing
- Ceiling fans on low speed down draft
- operable skylight open only about 1" or so acts like a chimney, sucks the hot air right out
- hot tea rather than ice drinks, learned that one in Istanbul
I planted a Norway maple and another type on the west side of my house twenty so years ago.  They shade my deck and rear of house, 10-15 degree difference in the shade.
When I built my pole barn for storage and wood shop I installed radiant barrier and then 4" of styrofoam separated with air space in the wall.  Even in 90+ degree temps I've never had the interior go above 74 degrees.
Fred
I had the idea of making a very loosely woven Scotch-bright scouring pad about 3” thick and about 4’ x 8’ with a film barrier on both sides.
These panels would be fastened to a roof with about a 6” spacing between panels.
They would work like the tropic roof on a Range Rover.  The top surface (Mylar?) would get hot and the hot area below the Mylar would vent to the edges of the panels.  This would be like having a canopy of trees over the entire roof.
I’m sure I’m missing something because it seems too simple.  But still, it seems like it would work.
They make high-reflectivity asphalt shingles that are supposed to reject a percentage of light and heat compared to black shingles.  The coloration tends to only last a few years as the lighter color gets washed away by rain and wear.
When we purchased our house, we had a 30" DBH (diameter at breast height) ash tree about 20 feet from the foundation that stood 40-50 feet high in the backyard (west side of our house).  We also had a 24" DBH maple that stood 25-30 feet high near our patio.  They were wonderful.  Our neighbor behind us also had a 75-foot tall linden tree at our property line that helped shade our yard among dozens and dozens of other trees. Our backyard was essentially a grove or meadow in the middle of a fairly dense urban forest.
August 10, 2020, we lost all of the trees to an inland hurricane/derecho.  The city overall lost 60-80% of its canopy.  Part of the ash came through the roof, and the maple deflected the linden away from the house and caused it to land between our house and our neighbor.  The ash and maple were too damaged to save, so they were removed (the ash was being treated for borer and would have been lost by now anyway), and I had both milled into boards and slabs.
On days like this week, I have to turn the AC up to 81 to get it to stop running in the late afternoon, even with all of the blinds closed on the back of the house to help reject heat.  We have batt insulation between the ceiling joists and another 6+ inches of blown-in on top of that, but I'm thinking of getting it all removed, seal any gaps and openings, and then re-filled with 18-24 inches of new insulation, but haven't taken the time to look for a reliable contractor for this.
We've planted new trees to eventually shade the house, but it'll be 20-30 years before they're big enough to start to help, and even longer to get to the point where they provide what the 50+ year-old ash provided.
Still can't decide on a pergola or awning for the patio; I have too many ideas and not enough decision-making space in my brain.
An ice 🧊 cold beer 🍺 and when that’s done…another ice 🧊 cold beer 🍺.
woodferret said:
swamp cooler.. not exactly 'lost' as the rest of the world and greenhouses still use it.
Swamp coolers have issues though. In areas with high humidity, the evaporation is not nearly as effective as it needs to be. Without that, not only is the cooling not working so well, it is also adding to the humidity already in the air.
In a greenhouse, that might be fine, in a woodshop, no.
I reap the benefits of a giant Maple tree, in my neighbor's front yard. It is diagonally south west of my house. From late morning on, it shades the entire front yard and about half of the house, getting better as the day goes on. The only down-side of it is that it absolutely requires gutter guards. When the seeds fly, it's a huge mess.
Swamp coolers would work in Phoenix (Arizona), if only they had the water supply to support them.
I was in Phoenix in 1972 and a local newspaper ran an article stating with their current population they were consuming more water than nature provided, and they should not approve any more construction to bring more people to the area.
The population of Phoenix in 1972 was 964,000.  It is now 4,770,000.
I guess the keep drilling deeper to find more water.
I used to live in the California desert, my house had a swamp cooler, in that climate they are quite effective and use a lot less electricity than refrigeration air conditioning. They were the traditional choice for air cooling, though a lot of the new houses in town used AC.
When I moved there I drove an MGB, I quickly learned that it was much more comfortable with the top up in the daytime.
A building detail not mentioned yet is high ceilings, and transoms over the doors.
basements or maybe for the older gentlemen root cellars [big grin]
I see a lot of references to shingles, which in OZ is pretty rare. Are roof shingles as common as it appears to an outsider?
Here it's mainly concrete tiles on older houses, or ceramic tiles or Colourbond metal roofing on new or renovations. We've actually just had our old concrete roof replaced with Colourbond, and the resulting insulation effect is just amazing compared to tiles.
I'm wondering what's the appeal with shingles as it seems to be very widely used, but requires a lot of maintenance from posts I've seen unless I'm reading it wrong?
Shingles are used a lot in the northern United States.  Hotter areas use clay tile or something else that is more heat resistant.  Shingles used to have an asphalt base but after the oil embargo in the 1970's manufacturers switched to a limestone base.  Now everyone has black mold streaks on their roofs because the mold is feeding off of the lime-didn't have that problem with the asphalt based ones.  Metal roofing is popular again.  Metal roofing is like vinyl siding-it looks good sometimes on some styles. sometimes not.  When I reroofed a few years ago, I used a synthetic slate product by EcoStar.
So yes, in the cooler areas shingles are still used but metal roofing is gaining ground.  Besides heat problems, there are also tax reasons and disposal of waste reasons why shingles are less popular.
The appeal with shingles in the US is cheap...cheap...cheap. And even more importantly, there are hundreds of companies that know how to install them. It's a race to the bottom when it comes to shingle installation. Metal roofing not so much.
I've always wanted metal roofing because of well...just too many reasons, one of which you've articulated. However, when I had the job quoted, it was a 8X factor over architectural shingles. Now granted, it was using a zinc & stainless material that was just flat out beautiful but even the normal metal roof was 4-5X the price of shingles.
And the thought of installing slate tiles or concrete tiles on a roof while looking terrific, results in some reinforcement of the structure to hold the added weight. However, when you consider that those same tiles will turn into a pizza oven on your roof when subjected to enough sunlight, well that does produce problems with the HVAC in the summer.
If I had the "opportunity" to redo the roof in the future, I'd consider the new photovoltaic options that are available. Tesla has some pretty interesting options, a better roofing protection product while at the same time "running the meter backwards" has a lot of appeal to me. I'm sure other products will follow.
What about the good ol' Breeze block walls a few feet off the south facing walls of an exterior wall of the home? I was told many places did this before insulation was a common practice to create shade on the exterior walls of a home to reduce radiating heat while still allowing natural light. Not too sure how much merit it truly holds but it does make theoretical sense to me.
I guess possibly a significant difference affecting selection would be the cost of heating/cooling?
Here in OZ we pay through the nose for gas and electricity, so we have many, many building and appliance regulations covering thermal losses and insulation requirements, and power ratings on pretty much everything. Some councils are now banning certain dark coloured roofing of any kind due to increased heat absorption.
I will say, after the new colourbond roof went on (which looks fantastic), the insulation they put in is incredibly effective. It's halved our heating costs. The vastly reduced weight from the concrete tiles will also be great so hopefully we don't get any more cracks develop.
My father talked about using the cooling bags after World War 2 in Southwest Africa to cool down beer and other drinks while driving.  Just hang them out in the breeze.  Had a swamp cooler in the house I first grew up in in Arizona.  Neighbors had air conditioning.  Loved going over to their house.  That swamp cooler always had issues.
