DrD said:Thanks much!! Just finished 1st video - 16 up and out for shelf holes - ok. Now, is this always true? And, if you use 32 up and out for the shelf pin holes, would you use 16 up and out for the 35mm holes? Just asking. Now back to the next video. Thanks again.
DrD
That's great if you want your doors to line up with the bottom of the cabinets but most frameless manufactuer makes the doors a little smaller than the box (3mm reveal a top and bottom and sides) so the doors are 6mm smaller than the cabinet.(each way)sancho57 said:Im shooting from the hip here, so if Im incorrect someone please correct me.
16 up and out sets the cabinet side so the shelf pins are divisable by 32mm. So that is why the end stop when attached to the rail you'll notice all the holes are "open on the guide rail.
The 32 up and out is used for drilling the mortise for the door hinge. When you put the end stop on with the 32 up and out you'll notice the first hole half way blocked by the end stop. This positions the guide rail holes so when you mortise the doors it will fit exactly inbetween the holes you drilled at 16 up and out so the hinge will line up with the hinge plate
Ift his makes sense.
mastercabman said:That's great if you want your doors to line up with the bottom of the cabinets but most frameless manufactuer makes the doors a little smaller than the box (3mm reveal a top and bottom and sides) so the doors are 6mm smaller than the cabinet.(each way)sancho57 said:Im shooting from the hip here, so if Im incorrect someone please correct me.
This gives you some room to make minor door adjustment.
So I don't know why anyone would want to use the lr32 to drill the cup hole for the hinges unless you have a small shim to compensate for the 3mm reveal.
Same here!honeydokreg said:When I use it for upper cabs for shelfs like display I usually do not put first hole until about 12" up. Then skip every other one and then stop about 16-12 " from top. You do not want it to look like a closet organizer for a built in
Now if doing a full length bookcase then maybe 8" up and down from top
If its for your own deal then whatever you like
If for job then realize most people don't want to see a lot of holes and usually once shelves are put in they never move um
