Rick Herrick said:Thanks [member=73094]afish[/member] . I have made a few cabinets now with my LR32 and really like it. I do want to figure out a method to stop using edge stops. One of my next projects is a kitchen pantry redo and I will have a few panels that are about 72" long and your suggestion is really the simplest way to get this done. Thanks.afish said:Also if you cut your panels using 32mm increments you can reference off the top and then bottom with just one rail. It requires switching the end stop each time. I would drill the same number of holes up or down from each edge just incase the panels length is off a half a mm or so.
No problem, Keep in mind you dont HAVE to cut your panel at 32mm increment to come in from both sides. If for some reason you are trying to match a height of some existing cabinets or cant make the 32mm work. There is a simple work around for drilling the holes and maintaining the 32mm spacing. For example well use your 72" as an example since it falls between 32mm increment.
72" = 1828.8mm
closest 32mm increment over 1828.8 is 58 x 32 = 1856
1856 - 1828.8 = 27.2mm
So you can cut your panel at 72" then rip a small piece of scrap at the 27.2 or any combination of 27.2 + any increment of 32 if you dont want to or if its easier not to make such a narrow cut. Now just take that piece and put it in between the top of the gable and the end stop (whatever end top or bottom side you choose you will need to do the same for all panels) dont put the spacer in the top on one and the bottom of the other. That should keep your 32mm spacing consistent from the bottom or the top which ever you choose. That is the simplest way I know of to use one 55" rail on tall gable panels not on the 32mm but I have a good table saw so it only takes me a minute to whip out a spacer. A cheap pair of digital calipers and any type of accurate saw table, miter will work.
You confused me a little by saying you want to eliminate "edge" stops since we're talking end stops but I do have some posts about eliminating the edge stops (for the most part) in another thread If you have or use a MFT style bench. The edge stops are the one part of the LR32 system that bug me. Dont get me wrong I think the LR32 is the best system overall and all systems have their pluses and minuses but those edge (not end) stops slow the LR32 system waaaaay down. Once I had my system dialed in to eliminate the edge stop it's amazing how fast you can batch out panels with the LR32
