lshah72414
- Nov 10, 2016
This is my first try with the frameless cabinet using the lr 32 system.
Cabinet is all assembled, drawer is in. Doors do not fit properly.
I have ordered the hardware twice. I am using Blum 170 degree hinges for frameless inset cabinets.
On the side of cabinet I am in 37 mm, the center of the screws are approximately on a line 38.5 mm inset.
On the door, the recess is 5mm and the start of the hinge is at 2.5-3mm inset.
I have enclosed two photos, one with door open and the other with it closed, and you can see how edge of door is out approximately 18 mm. I have adjusted it in as far as it will go. AM I using the wrong hardware? Did I do something wrong. If I move mounting plate in on side of cabinet I can solve problem, but then what is the good of the lr 32 system if I do that? thank you.
