LR32
I don't think so. It would be considered an accessory, not an actual power tool.
If you are tight on budget, get just the minimum set with the plate and the mandrel only.
All the other pieces can be jigged-up or replaced by other ways to place the rail. E.g. the TSO parallel guide etc. etc.
And worst case you can get them later individually.
Good point on the tso parallel guides, I already have them and didn’t think about using them. I’ll look into the lesser set.
And this might help....
Then you don't have to fiddle with the ruler on the parallels and just use them as a story stick if you're doing multiple panels.
Last month the 12 piece bit assortment set 205090 was listed on Festool Recon, which would definitely be an accessory.  I did find it strange that it was listed on Recon, but accessories listed on Recon can happen.
I bought my LR32 on clearance because it was in the old style systainer, so discontinued. Therefore dealer could discount. Unfortunately, that was a couple of years ago so imagine most of those are now gone.
Same here…I visited my local Woodcraft store and an unopened LR32 appeared for 40% off, it didn’t take long to pull the pin.
I might remember wrong... but way in the past... I think the LR-32 set did come with "points", just like the MFT. But besides that pretty much only the power tools did.
