Birdhunter
- Jun 16, 2012
I was tasked with building a tea table for a friends. I’ve made two of these some time ago. The design specs from my wife was that the table had to look delicate. The top had to be 8” by 16”. The stretchers were 2” high. The legs were 16” high.
The previous tables were joined using my Domino. With only 2” to work with. I used just one tenon for each joint. I did have a problem with one set of joint coming unstuck. I think the cleaning ladies probably banged the table with the vacuum cleaner.
This time I pulled out the Mafell dowel machine. I had to play with it a bit before I got the correct dowel spacing. I ended up with 2 40mm by 8mm dowels in each joint. Perfect alignment
I used my new Woodpeckers taper jig to double taper each leg.
Now comes the sanding and finishing.
