DanielOB said:how to make tenon 1/4-1/2" thick AND 3-3.5" deep
I newer saw a bit for router that long
This is a typical tenon for solid-wood door
Tyler Ernsberger said:I have used a Porter Cable Lock Mortiser with great results. Plus its made to fit on a door already. Pretty expensive, but you if you look around a rental places you can rent for a day. I own one that has 1/2, 5/8, and 3/4 cutters.
. Egg-zackly ^^^^neilc said:You can also cut a tenon on a band saw - saw close to the line against a fence and then use a hand plane to shape to final dimensions
fshanno said:You see where I'm going with that question.
