Screen door joinery
Scottp57
Hello,
I’m making a cedar screen door for the porch that will be 1.5” thick and 36” x 84” with 5.5” wide stiles and rails (top, middle and bottom). I have a DF500. If I used the 10x50 dominoes for the joinery would that be strong enough or should I do traditional mortise and tenons?
Hi [member=82990]Scottp57[/member],
Contingent on proper placement, design, etc...., Dominos should be just fine. I toured several door/window factories in Germany last Spring, I don't think I saw a single door or window using mortise/tenon joinery. These were 68mm+ doors and windows with triple pane IGUs, very heavy, and relied on 12mm and 16mm Larch dowels.
On a ~38mm door, I'd suggest bumping to 12mm Dominos, and you may want to consider the Sipo Dominos, which are intended for outdoor projects.
Dowel boring pattern from one of the window factories:
I built two screen doors using 1-1/4” pine.  The joinery was three, 3” x 1/2” dowels per joint.
One door is about 6 or 7 years old.  The other is about 5 years old.  No signs of joint failure for either.
I would guess that three dowels will be stronger than one domino and three dominoes would be stronger than three dowels.  More important is that the fasteners be of a good length. I’ve seen people using really stubby dominoes and I probably would choose something longer.
I doubt that the domino would fail, but the mortise in the wood might.  Greater depth would mitigate that possibility.
Screen door at the front of my house.  The house is a mid-century influenced design (meaning no crown moldings anywhere).  The front door has three portals to look out on.  I laid it out so all three portals have no visual obstructions.
There are 10 joints on this door, so pretty strong with 3 dowels per joint.
The screen door for the rear of the garage (the older of the two doors), and a more conventional layout.  Also 3 dowels per joint.
Both doors have removable screen panels.  I got the rolled trim for both of the doors from Home Depot.  I also got joiner corner pieces (molded plastic) that allowed me to use just square cuts.  I used turn buttons to hold the panels in place.
But note, the molding is not very robust and rolling in the screens tended to make the panels bow inward.  To deal with that I used 1/4” nominal plywood strips as spacers to prevent the bowing.  That worked.
For the front door, I used the bronze anodized molding (also from Home Depot) but I got the hidden joiners from Amazon.com that allowed me to use mitered joints.  I think it looks better, and I have my sliding table saw with dedicated 45 degree angle cuts only.  Those cuts are very clean.
I had intended to use the plunger type of fasteners to hold the screens in place, but I decided that they required more effort than they were worth.  (The drilling jig was going to take too long to make.)
The corner hardware and plunger hardware are from Amazon.com.  If you have a miter saw that will make very clean cuts on thin aluminum, I recommend it.  As I recall, my miter saw has 180 teeth and was punishingly expensive when I bought it in the 1980s.
I would note that if you are going to cut the stub tenons on your table saw, you can increase the strength of the joint by simply increasing the length of the tenon and the depth of the groove.  For a screen door, I would probably use 1” long tenons.
I believe that router or shaper bits make 1/2” deep stub tenons. My instinct says that going to 1” deep tenons will double the strength of the joints, but I suspect that is not exactly correct.  It will be stronger, and if you are cutting these on the table saw, no extra operations.
If you are going to have drop in screen inserts, you will have to remove most of one side of the groove.  I would do that after assembly because I would end up removing the wrong side of the groove.
As an aside, fiberglass window screen fabric is strong enough to resist most damage from pets.  They are sold as “pet-proof”, but don’t bank on that.  A determined dog will have no problem ripping either the fabric or tearing out the splines.
I did some work around the multi-million dollar mansions in Sands Point, NY (Long Island) and all the older mansions had bronze fabric for the screen material.  It was vastly stronger than the aluminum mesh, and probably stronger than the fiberglass mesh.  Expensive, but you don’t need much for one door.  So if you want an easy upgrade in quality and appearance, use the bronze material.  It installs just like the other mesh, though cutting it will require a shears instead of a utility knife.
The local hardware store in the area carried the bronze mesh.  You can still find it online.
This company only sells full rolls ($$$$); I’m sure a google search will find a vendor that will sell by the square foot.
https://www.metroscreenworks.com/ro...kKpvyrus0Btrw5OgIdm4uKdpuIEZbWqoaAs5FEALw_wcB
Addendum:  As I recall, all the bronze screens were stapled in place and the staples covered with screen molding.  I’m not sure it will roll into the screen molding and vinyl splines.
Hey @Scottp57 did you finish your screen door? I created some plans for a screen door and I'm looking at using cedar for it's rot and weather resistance.
Would love to hear your thoughts on working with cedar and how the doors turned out.
Thanks!
