Maple Slab Coffee Table
Bruce PHL
The commission?
"I want a low coffee table that looks like you made it for me."
The slab started out looking like this:
I made two angled cuts (with TS55 and a guide rail--each cut in three passes of increasing depth), repositioned the middle piece against the outer two and re-glued to make the board more square.
Then, I cut table approximately square with, you guessed it, my TS55 and a guide rail, blade set at 10 degrees--again, in three passes.
It now looks like this:
Thanks, Peter--
It was planed flat with a rilly, really, reeeely sharp blade, then tung oil.
Surprisingly, it gave me no argument during planing.  I started with a Stanley 605 plane with a Veritas A2 blade (what I used for the edge jointing), thinking I would just clean up the glue joints, flatten a bit, then use my HNT Gordon plane to finish.  Things went well with the Stanley plane, so I chose the path of least resistance.
However, the glue up was a special kind of fun (not) and that's when my vocabulary was, um...nothing to be proud of.
Nice! It does come back to the wood. All that work on the wrong piece of wood and you have nothing. With the right piece of wood, things are wonderful.
Cheers,
Steve
Thanks.
I am embarrassed to admit it, but I spent hours staring at the board...trying to figure out where to cut/what angle/where to reposition.
Finally, I came to the conclusion that it was a puzzle with no one solution, started sawing, and hoped for the best.
Again, thanks--
However, there was some bitchin' figure/grain/spalting on the original slab (center bottom and center left sides of photo) that didn't make the cut.
My apologies for the lame pun.
