Material for cabinets for motorhome
bmikl
I am working on an older motorhome that sustained a lot of water damage over the years (rotten walls, etc.) I removed the old cabinets which were oak, very nice quality. Most of these cabinets had to be cut apart to remove them. I would like to make new ones but out of a different material other than oak. The motorhome will be subject to a wide range of temperatures and humidity. Are there any suggestions for material suited for this type of environment other than oak?
If you are talking about cabinets I think that you would be ok with most anything.  What would be more of a concern I would think rather than temperature would be humidity and also the fastener holding aspects of the wood.  Motor homes have bumps and vibrations.
I have built 3 buses,on my fourth.worked on many more.what I found to to be bombproof is weld metal frame,cabinet grade plywood skin ,bolted and screwed&glued.problem with motorhomes is they are all wobble boxes,i wont work(construction) on motor homes,except for friends,just buses.never comes out as good as new,always flaws
