yoda said:I've got a ct26, kapex and ts55. A large portion of what I do involves cutting and sanding MDF. Anyone else use a long life bag for this and how well does it work?
i can fill a bag easy on one job with my ct mini, i cut up 8 sheets of 18mm mdf for some wardrobes and profiled some edges, filled a whole bag! i need to get the midi as i regularly fill the bags on the mini and i re-use them around 3-4 times.jonny round boy said:yoda said:I've got a ct26, kapex and ts55. A large portion of what I do involves cutting and sanding MDF. Anyone else use a long life bag for this and how well does it work?
The long-life bags are designed for coarse waste, for example large chips from routing & planing. They are not recommended for applications that produce fine dust (sawing, sanding), especially in MDF.
Stick with the regular bags. Cutting & sanding MDF, you'll be surprised just how long it takes to fill a 26 litre bag!
Dan1210 said:i can fill a bag easy on one job with my ct mini, i cut up 8 sheets of 18mm mdf for some wardrobes and profiled some edges, filled a whole bag! i need to get the midi as i regularly fill the bags on the mini and i re-use them around 3-4 times.jonny round boy said:yoda said:I've got a ct26, kapex and ts55. A large portion of what I do involves cutting and sanding MDF. Anyone else use a long life bag for this and how well does it work?
yoda said:Thanks for the responses. Any chance there is a third party manufacturer that makes re-usable bags for the vacs? >$200 for a jumbo ziploc bag seems a little steep. [tongue]
Tom Bellemare said:The Festool Long-Life Bags are significantly more than any Ziploc I've come across. A Ziploc more accurately equates to a disposable filter bag.
The Long-Life Bags are tough as nails and have the same filtration as the disposable filter bags (5 microns). The reason they are not recommended for hazardous or fine dust is that you have to empty them and the dust can go airborn in the process. If you are emptying the bag and the dust goes airborn, you're likely breathing it.
Dan1210 said:The concept of festools paper bags is brilliant and works amazingly well! you set up your tools, machine your material pretty much completely dust free when using all festool kit, then when your done or your bag is full you open the extractor flip over the cardboard lid and all the dust is contained! and it really is that clean, but the catch for me is i fill a bag very quickly and having to buy the bags can be heavy on your wallet.
So i find myself re-using the bags 3-4 times and getting very dusty in the process! kinda defeats the object, it wouldnt be so bad if festool bags were offered at a reasonable cost but they are fairly expensive compared to other domestic bags, im with jmb on this one and will be after a long life bag soon, i think they are £25 for 5 in the u.k £5 a bag! someones taking the piss somewhere...
Dan1210 said:the catch for me is i fill a bag very quickly and having to buy the bags can be heavy on your wallet.
RMW said:Dan1210 said:the catch for me is i fill a bag very quickly and having to buy the bags can be heavy on your wallet.
You might consider adding the Dust Deputy, I bought one at the same time I got my CT 36, I think I have emptied the DD 3 times and the CT 36 bag seems to be nearly 100% empty still. I also seem to have 100% suction also.
The DD comes with a few clear plastic bag that I assume are meant to be disposable but, being cheap, I just pull the bag and upend it into the bottom of an empty garbage can with a green liner installed and then gently pull the DD bag out by its bottom, no dust issues at all.
If this keeps up I may never have to replace the bag on the CT 36.
Deansocial said:Dan1210 said:The concept of festools paper bags is brilliant and works amazingly well! you set up your tools, machine your material pretty much completely dust free when using all festool kit, then when your done or your bag is full you open the extractor flip over the cardboard lid and all the dust is contained! and it really is that clean, but the catch for me is i fill a bag very quickly and having to buy the bags can be heavy on your wallet.
if you are just using the mini then buy the numatic hepa bags and just cut a bit of the green plastic off it and they slip straight on. I have been using them on my midi now for ages and they work great. I dont buy them my self the company i sub to does but i think they get em for £6 for 10
