Thought I'd post my opinions on the new Matabo rails, having used them on several projects now.
I've been interested in the most secure way of joining rails for a while now, as I never liked the standard festool or makita rail connectors. In my precise work I guess I am working (or trying) to the most accurate tolerances I can achieve, given the thickness of tape measure marks and mechanical pencils. I always struggled to make an accurate 2.4m cut with two joined rails. Being off sometimes by nearly 2mm in the centre of the cut could be common without due diligence every time.
Secondly I had for a while liked the idea of a 1400 rail (all I often need on an install) in two parts in a smaller bag/package.
So to keep my 'trial' costs down I purchased the Metabo 1600 rail and chopped it in two to test the system.
I have to say that so far I love it. While a 1600 joined track length is not as easy to test/push the accuracy and reliability of the joining system as a longer 2400 cut, it has been perfect none the less. A cut along the length of the joined 800 rails is absolutely spot on straight. I love now having this smaller rail bag in my kit with a 1600 rail inside.
Having seen how well it works I'm interested in having three or four 800mm tracks in the small festool bag. Having reliable long tracks in a small package for storage and transport is a real dream come true for me.
EDIT:
A bit more info. . .
- The glide strips on the top face are like the makita with ridges rather than smooth like festool. This concerns me mildly as I've seen the makita rail wear the baseplates of saws over time quicker than the festool rails.
- All the underside strips are rubber extrusions that side into the profiles in the rail. I was concerned about the grip of the slim rubber traction strips but they have performed as good as festool on sheet goods so far. The splinter guard is a little loose and wobbly when the rail is off the work piece, but resumes a consistent position every time the rail is placed on the work piece.
- The joining bar appears to be exactly like the mafel/bosch one but I've done no direct comparison.
- The 1600 length feels very secure when joined and the transition of the saw between rails is imperceptible in use.
