MFK 700 or other trimmer?
Holmz
Using some veneered MDF or similar, I would like to put real wood onto the edges.
Something ~7-mm to 1/2"...
Enough for a #o biscuit to hold the wood on and some fat to sand it without "breaking on through to the other side"... Probably more like 10-mm??
So if that wood is proud of the veneer then I need to trim it.
My choices seem to be a file or rasp, or a power tool.
There is the MFK700, but I am not sure of the length of cut?
Or a regular router and some contraption to keep it normal to the edge like a rod which I saw a few weeks ago (I think was a plastic rod).
Or some Swiss or Austrian or Spanish edge planner. Maybe with a 1.5 degree draft angle.
What is easy/cheap?
A roller bearing and the plastic rod followed by a file?
As I may have a number of pieces to make... What is optimal if I ignore cost?
The 3/4" wide edge on this table was done with the 1010 and lipping plate. If it was less that 3/4" I would have used the 700 with the horizontal base.
Either/both are so accurate that I can undercut the edging just enough that the dried finish film lines up with the top of the laminate.
Optimally and ignoring cost, the best choice is a lipping planer.  Either Lamello Cantex, Adler, or the Virutex.  I have the Cantex and it is a great machine but costly.  My experience has been this gives a much smoother cut and is much less prone to tear-out than a router bit.
The MFK is also a good choice but once the width of the hardwood gets over 6 mm, the 1.5 degree base becomes very noticeable (at least to me).  If I went that route, I would opt for the 0 degree base which will add cost.  For the MFK, you will be limited to a max width of about 15mm.
If you have either the OF1010 or OF1400, the edging plate will also work but I found this is a bit awkward for me with the OF1400 as it is heavy.  This probably works better with the OF1010 that I don't have.
Another option is the table saw.  William Ng has a video of a jig ( )  starting at about 6:40 he shows how to trim edgebanding.
Steve,
I asked this question on another forum, never got an answer----
Can you adjust/control the inward depth of cut accurately on your lipping planer? On the table I posted, I had to cut right along the edge of the laminate without chipping/damaging it. As I said, I undercut the lipping 0.007" so the dried finish lines up with the top. Is the inward adjustment accurate enough to do this?
I do have the 0º base for the 700. Anything over 3/16 and the 0º goes on the 700. Anything over 11/16" I use the 1010 with the lipping plate.
Thanks.
Crickey!  That seems like a Serious tool.
I already have a Zeta-P2, so I assume that this is also of "Swiss watch" quality.
I do not have a 1010 nor a 1400, just a different 8-mm router which I like for freehand work.
Also I have no table saw, but that tablesaw work looks to me sort of like a router table approach.
The Cantex is also the most expensive of the group.
The others are included for completeness...
Adler/Hoffmann:
virutex CE 89:
I am thinking of used a composite panel with end grain balsa and fiberglass face sheets.http://atlcomposites.com.au/icart/products/92/images/main/Duflex Balsa.pdf
Ignoring if one wanted the sides to be contrasting... The 2 options are:
1) Attach the sides first then flush trim, and then laminate/veneer
2) Veneer first and then attach the sides and flush trim.
Option #1 seems more straight forward...
But what do people using veneer on MDF do?
In the end I will stick it together with ClampeX, and then break it down and ship it 1/2 around the world. Hence that is why I am weight and joinery approach focused.  [embarassed]
[member=40772]Holmz[/member]
Can't believe you can't use the red jigsaw  [big grin]
If the edging is only a fraction bigger than the board. And you are going to locate with a biscuit. A skim with a sharp plane and a sand would be enough I would have thought. No need for a trimmer
[member=32795]VW MICK[/member] I doubt that the red jigsaw would work....
But maybe I am overthinking this?
I ordered some biscuits last night and a TOP-21 cutter blade.
So I was thinking if the rails/stiles were outboard of the veneer then I maybe I would put some tape on a hand plane to scoot across the veneer... If the edging is under veneer, then it gets easier.
I suppose I should just 'ave-a-go and see?
tjbnwi said:
Steve,
Thanks.
Tom,
Yes, it is extremely accurate.  Each click of the adjustment is 0.035mm height adjustment.  To do what you describe will require the optional fence.
Steve
Maybe [member=60286]bobfog[/member] , I just considered that I want a lot of "something" behind to keep it all flat. I would have to use it from the side to trim the top and bottom of the trim material, so the MFK looked right, but maybe too short.
I find it interesting that I was looking at power tools and VW MICK suggested a handplane, and I did the same yesterday in another thread. It is hard to think as clearly When one is too close to the work.
I need to get a table saw to get the small pieces close, they are a bit too small for a track saw.
The simple answer for me would be to use a hand plane set for a very fine cut - I do it all of the time with solid wood edging.
I have the MFK-700 and love the router.  I use it for the flush trim set-up but have also found it works really well as a small router and a nice compliment to the OF1400.  I used to think I would some day get the OF 1010 but probably not now.
Put another way, it is more than a trim router.  I find it to be more versatile.
Everyone raves about the FT routers, but I have not used one.
I did put the paws to a 1400 in a shop, and it seemed familiar, so it must be that all the Elu -> deWalt -> etc ... result in some consistency.
But to me that 700 seems distinctly worth a closer look.
Back to the process...
It seems that the MDF with veneer on them need the rails/stiles outboard.
And layup on a composite panel I have a choice.
(I'll probably do the MDF first for a bathroom)
I know what you mean. It is a nice tool and I do fancy one as I have a couple of projects coming up where I could utilise it. But it just seems so expensive for such a niche tool. The Makita I was looking at, whilst being 1/4-1/3 the price depending on what kit you get, it also has a decent depth adjustment range, which the MFK700 doesn't seem to have.
Maybe the OF1010 and edge trimming guide would be a more versatile investment...
