I needed to knock off the edges of the raised panel doors that I had just made. I had a roundover bit that I put into my MFK700 but immediately ran into a problem. No matter what I tried I could not raise the roundover bit enough to not create a bead. It finally appeared as if I was going to have to use my OF1400 to solve this when I had one last thought. I would very much like to know if anyone else has tried this and/or what your thoughts on the danger aspect my be.
So, my solution was to raise the MFK700 out of the base by approx. 1/4" and then tighten the knob. This was a perfect solution and gave me the correct height for the bit. If this is a constant problem it would seem to me that the shanks on some of the MFK700 bits should be shorter as this would also help. Fred
