MFT 1080 Top Hole size
msw
Can any one tell me which router bit size to use to bore the hole for the MDF top I am making for my MFT 1080
The newer tables had slightly smaller holes - maybe 19.75 mm. The older ones were 20 mm... There's a thread on this somewhere here. Maybe one of Qwas's?
If you have an MFT (or an MFT table top bought as a spare part)
clamp the 3/4" MDF on top of the MFT, then
drill 13mm holes using a brad point bit at every wanted  hole location
from underneath the MFT top, then use a 1/2" copy router bit
from above the MDF piece to
That way, you have exactly the same hole diameter as your MFT top,
whatever it is ...
