MFT 3 - Should I Buy One?
Petey83 said:
Had another little girl lay with it today and I'm pretty happy. Think I'll invest in one of those plywood squares for speed of set up as mine has to be totally disassembled for storage due to limited space.
It's bigger and more solid compared to the keter and top combo set up I had and just the extra height makes it more pleasant to use.
The MFT is at 900mm what kewl about that is its the same height as all the festool meaning Kapex in the stand or MFT is at 900mm, the Kapex on the  Kapex MFT  900mm
Lots of possibilities there
Petey83 said:
Had another little play with it today and I'm pretty happy. Think I'll invest in one of those plywood squares for speed of set up as mine has to be totally disassembled for storage due to limited space.
Although I wouldn't disagree that it's wise to have a good square, for speed I find the Parf Dogs and Bench Dogs brilliant.
Particularly if you are disassembling and setting back up on a regular basis.
