Hey Sourwould,tallgrass said:If there is shipping involved than I think you are right.
As a local Woodcraft employee, I definitely think you should return this to Woodcraft. Especially if you paid $720 for the full MFT 3. The stops are factory set to allow you to set your rail up consistently with the protractor head and attached fence. BTW, for whatever reason, buying the full kit from Festool is the only way to get the supports, protractor head and fence with the various pieces. If we had the same situation at our Woodcraft there would be no questions asked.....a refund, or a return would be immediate and unquestioned, and that is also Festool USA's position. The primary reason to frequent local Festool dealers is the support you get and should expect and the knowledge that the tools and equipment you purchase are new, functional, complete and undamaged. Where are you located?
P.S. - the design of the rail supports is such that once you have a tool on the rail, there is no slop whatsoever. Setup is not difficult, but not intuitively obvious either. You can find several videos on festooltv.com for proper MFT setup.
