Hey guys,
I now have an Incra LS Positioner to go along with my MFT/3-VL and was wondering if anyone else seems to have any problem with:
1) Getting the VL extension perfectly level with the MFT/3
2) Getting the TS insert plate perfectly level with the VL (it seems to sag in the middle and has a couple of other 'high' spots) ???
For the VL, my process has been:
* Loosen the nuts near the MFT/3 and using a steel straight edge bring the extension in line with the MFT/3 (the photos show a small square however the result is the same with my metre long one as well)
* Tighten the nuts
* Bring the legs up to the same level
This gets it very close, however, I think the main issue I have is with the insert plate as there are no adjustments.
I've considered screwing in some reinforcements underneath the plate (have seen another member of FOG do the same) however before I go modifying anything I thought I would see what everyone else has to say.
* Tighten the nuts
