MFT/3 Wheels
IndyRick
Hopefully this isn't redundant, but my search didn't see that this had been posted before. I need to get my MFT/3 outside to work, and it's really to heavy for me to lift. However, I had some 12" wheels sitting around from a project that moved in another direction. A run to the hardware store for 4" long 1/2" bolts, 2 fender washers, and a wing nut provided the hardware.
I'm not sure which direction is forward. In my case, I'm moving this out to use in my driveway. As I move it off the porch (only a single step), I have to support it until the rear wheel is at the edge of the porch or the frame will scrape. When I set it up, I start with the legs opposite the wheels. I nearly always need to remove the wheel in the way of the fence, and often have to remove both.
Since neither wheel pivots, steering is non-existent (and can be a challenge).
