MFT cross members modification
QuammeA
I had recently picked up a MFT 3 along with some extra tools including the optinal cross members for added stability.  I installed them how I thought they should go since the instructions were lacking and I am a Civil engineer, I should be able to figure it out.  It turned out I was installing them wrong or at least one of them.  I installed one on the front and one on the rear and they made the table very sturdy.  The only downside was one of them was not easily removable unless you loosened the bolt on the bracket that attaches to the top rail.  I searched YouTube for more instructions and plaid and stopped a Festool guide video of setting up your MFT 3.  It turns out that both of the supports are to be installed on the rear of the MFT 3 and not like I installed them.  I called Festool support for clarification and they said that they were designed that way so there was no obstruction rolling your CT vacuum under it and not for maximum stability.  So I am going to make my own bracket unless someone out there has already done so then I will buy it from you.
The Norwegian woodworker said:
...and not for maximum stability.  So I am going to make my own bracket unless someone out there has already done so then I will buy it from you.
I've considered building some a few times.  What's the plan/design?  If I were making some I'd make shorter braces for the front legs that run at a 90* angle and the ones you purchased in the rear.
Edit:  I went and looked at the set you can buy and am wondering how you mounted them incorrectly?  These are the ones or is there a different version out there?
Would you have some picture of your current mounting ?
Would you have some draft drawing of what you are thinking about ?
I looked, searched, called, and I'm still not sure I have mine mounted "correctly" - that is per Festool design.  Help AND pictures appreciated.
Don G
As far as I understand, this is the "correct" way to mount the cross members. On the "back" of the table as you face it, the guiderail would be on your right, hinged at the back. Anyhow, this is how I have mine installed...
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
Thanks for the photos.  As you show, is how I ultimately - after several tries - set mine up.  As I recall, I had difficulties mounting to underside of table to give stability and allow for "quick release" to fold up table.
The way you show really does measurably increase stability of table.  I would get a second set for my other MFT if they weren't so dadgum expensive.
Don G
Just bolt a CMS-VL on either side and it'll be a lot more stable [scared] [eek]
