Crazyraceguy
- Oct 16, 2015
My needs are apparently more like [member=73094]afish[/member] I have a 49 x 97 table with 325 holes and a 30" extension that is smooth (no holes) I use it for clamping, fixturing every day, while only occasionally cutting. I don't exactly cut in a conventional manner though. It is drilled to have the second row from the end line up exactly with the width of a Festool track, so I can cut off of the end, making no kerf in the table surface.
I have two rolling carts that are the same height as the table, which allow for support of the off-cut piece.
This is not ideal for all cuts, but it doesn't need to be, (I have a permanent table for the majority of track saw cross cuts.) but it works for the occasional cut, when it's more convenient.
I have always relied on dogs, as that was pretty much the standard, back when I built it. The MFT hinge system was basically a Festool extrusion mounting exclusive and alternatives weren't a thing yet.
Since my table is 4' across, a hinge is not all that attractive to me anyway. Without a way to keep it up, without going over-center in the back, it's not practical.
