I have been tinkering with this off and on for the last three or four years. I have the 25 inch positioner on order, and am working to fit this onto my CMS. I'll post pictures of that in another three or four years, hah. Anyway, here's my "lovely" setup. You can see the square in the picture - that's the easy part - nice and square like it is supposed to be. The only "off" part is that I secure the end of it on the "wrong" side. This was to make it so I had more than 24" of cutting capacity on the table. I can squeeze just under 27" if a little bit hangs over the side of the mdf before the rail adapter on the side (25 1/2" on the table).
The positioner is secured with two qwas dogs underneath, and then clamped down. I use two of the small dogs to reference to the fence when it is locked, then I clamp the base down on the side opposite the qwas dogs. It is as rigid as you could hope for. I'm not the strongest guy, but the table picked up and moved before the fence flexed that I could notice.
Here's a close-up of the easy part of the job...
And now the good stuff - perfectly square to the LS.
Measurement randomly locked into place - 1'2 1/8" at the rail...
1'2 1/2" on the opposite side of the table. That laser has a 1/16" tolerance, so the variance would seem to be less than that - which is relatively solid in my opinion. That's just under 1.6mm - which isn't perfect, but again, this isn't a felder slider...
The current setup can handle 25" wide by 22" long with the current LS in place (soon to be 30" with the new model). The flag stops are good for my scatter-brain self. Just push them up against the locked in fence and they're good to go.
