- Nov 14, 2013
Disclaimer: I am trained as an EMT, but am in no way 'the definitive source' on anything medical. I believe that I am better than average at explaining things, so I am posting these tips in the hopes that they will help someone to be better informed or more prepared. They are not intended to be a substitute for appropriate medical training, and you should ONLY attempt first aid that you feel comfortable providing and are trained for. There - that oughta satisfy the lawyers!
;D
By the way, I will update this post to add more tips, correct any errors, or to clarify something. Check back often!
We're getting closer to having the Mini-Trauma / First Aid Systainer ready to ship. Since not everyone here is trained as an ER Doctor - including me - I thought I'd offer up some help in "bite-sized' chunks. These tips are relevant whether you ordered a kit, made your own, or are just thinking about getting one.
*** Thursday May 15th - When should I use Quikclot?
Quikclot is a great product when used properly, and a PITA for the ER folks if used incorrectly. While misuse typically isn't fatal, it can seriously complicate the cleaning and final treatment of the wound. So, when should you use it?
Only use QuikClot if:
• Direct pressure over several minutes isn’t stopping the bleeding.
• The compress/trauma pad becomes saturated with blood quickly and repeatedly.
• You are many miles from any medical assistance.
Also, Once QuikClot has been applied, NEVER attempt to remove it or expose it to water. Doing so will also remove the clot, which puts you back to square one - or worse. It should only be removed in the ER where they can deal with rapid blood loss.
Do not use QuickClot:
• As a first resort to stop bleeding. Always apply direct pressure to the wound FIRST.
• To delay treatment. If you need to use QuikClot, you need treatment NOW.
• If an ambulance or rescue can reach you in minutes. This means that you will typically NEVER need to use QuikClot in a metro area.
*** Friday May 16th - Why give heart patients aspirin before they get to the hospital?
Aspirin is one of the most important medications we have for treating heart attacks. Unlike when you're just taking it daily to reduce your risk, this is an emergency. In this emergency setting, taking an aspirin can reduce your risk of dying from the heart attack by about 20 to 30 percent. It's one of the most powerful and most important medications for the treatment of a heart attack. By the way, be sure you CHEW the aspirin to get it into your system faster. Yes, it will taste bad.
So why do paramedics give patients aspirin before they get to the hospital? They do that so it can be provided early, and they also do it so it's not forgotten. If the patient ends up getting an extra aspirin in the emergency department, that's okay - it won't hurt them.
While there's no strong evidence that you need to take it within seconds of the heart attack's onset, there's likewise no evidence that you shouldn't. It's important to administer within hours - certainly within 24 hours of the onset of a heart attack - and it's probably true that the earlier the better.
The important thing is that someone who's having a heart attack does get an aspirin. If you want to take an aspirin the moment that you believe that you might be having a heart attack, it's not a bad idea.
As far as dosage, Bayer says: "Taking at least one half (160 to 162.5 mg) of a Genuine Bayer Aspirin during a suspected heart attack can help save your life. And, if you've survived a heart attack, a doctor-directed aspirin regimen can reduce your risk of a second attack by 30%."
Most Paramedics and ER's will simply give you ONE adult strength aspirin, as a little extra won't hurt.
Credit: Harlan Krumholz, M.D., S.M., Harold H. Hines, Jr. Professor of Medicine and Epidemiology and Public Health, Yale University School of Medicine. Edited 5-19-14 to add Bayer information.
*** Monday May 19th - Blood is good - cuts and scrapes 101
Blood helps clean wounds, so a little bleeding is good. Most small cuts and scrapes stop bleeding pretty quickly, but you can help by applying firm, gentle pressure with gauze. If blood soaks through, put another piece of gauze on top. Don't remove the old one or you may start the bleeding again.
• Clean Cuts and Scrapes Gently
Soothe and clean the wound with cool water. Then remove any pebbles or splinters with sterile tweezers. Gently wash around the wound with mild soap and a washcloth or gauze. You usually do not need to use harsh soap, iodine, alcohol, or hydrogen peroxide -- fresh, clean water should be all you need.
• Apply Antibiotic Cream
Antibiotic creams and ointments not only keep wounds moist, but they can reduce the risks of infection. Apply a thin layer on the wound. Certain antibiotic ingredients can trigger a rash in some people. If you get a rash, stop using that ointment.
• Apply a Bandage
An uncovered scab or scrape is at risk of reopening or infection. Cover it up with an adhesive bandage to keep out the bacteria (and your prying fingers). Change the bandage daily.
• Signs of Healing
Almost as soon as you get a cut or scrape, your body begins healing your injury. White blood cells attack infection-causing bacteria. Platelets, red blood cells, and fibrin create a jelly-like clot over the wound and soon a protective scab forms. If your wound gets itchy, be gentle -- you want that scab to stay where it is.
• Signs of Infection
If there's skin redness that spreads out from your injury, swelling, green or yellow fluid, or increased warmth or tenderness around your wound, you may have an infection. Other signs include swollen lymph nodes at your neck, armpit, or groin, as well as body aches, chills, or fever. If you have any of these signs, give your doctor a call.
*** Tuesday May 20th - Dealing with Diabetes
Diabetes is a potential emergency, and *MAY* require immediate action.
Reaching a 'sugar high' condition takes a long time, and can usually be dealt with as a non-emergency. If the patient can't self-correct using their insulin, get them to an urgent care center or ER.
A low-sugar condition, however, is a real emergency requiring action within minutes. If the person is failing but conscious, you can simply allow them to drink regular soda, juice or energy drink. But you should never give food or drink to an unconscious person.
If they are unconscious, first call 911. If you have glutose, creamy peanut butter, frosting or something similar - and have been trained to do this - place some of it on the end of a tongue depressor (conveniently included in your Systainer Kit !!!) and slip it between their teeth and their cheek with the sugary stuff toward their cheek. This will allow them to absorb the sugar needed to deal with their condition, while minimizing the risk of choking.
When in doubt - If you aren't sure whether their sugars have gone low or high - but they are still conscious - give them a sugary drink like regular soda, juice or energy drink. The small amount of sugar they will receive will help them if they are 'low', and won't be enough to be a serious problem if they are high. Obviously after an episode like this they SHOULDN'T drive, and they SHOULD be seen by a doctor.
Simple and effective - and you can always cancel the first responders if the patient comes around. But if the treatment doesn't have a positive effect within a few minutes, you already have the right help on the way!
I'll have another TOTD tomorrow. Let me know if this helps and/or is of interest to you?
;D
• Apply a Bandage
• Signs of Healing
