SittingElf
- May 28, 2013
Slartibartfass said:Frank, where is the big boom arm you got if i remember correctly.....? Come on you are only showing half of the stuff...
I have to wait until my shop floor is redone. We are sinking a steel beam into the floor and anchoring it above the ceiling in order to support the boom. My contractor has worked out all the math, and it will work great once we complete the shop. Slow process when I can only spend a few weeks at a time in my Florida house for the moment. (Have to spend quality time with my wife and son in Georgia where my wife is currently stationed, then back to the grind for six weeks in Nigeria. Ugh! Nonetheless, progress is slowly being made.
Other than machinery, the following steps are still in process:
1. Floor of the shop being completely laid with Porcelain tile. (Yup... it's a new thing but those who have done it rave!)
2. Complete electrical wiring with 110 and 220 outlets throughout. Need as high a a 50amp 220V breaker for my 20" Italian Bandsaw, with its 6HP Baldor. Then the rest can be 30 or lower. Single person shop, so no more than two machines (including the DC unit) on any time
3. Ducting through the attic and down into the shop for my Dust Collection of the big machines
4. 2.5 ton AC/HEAT/DEHUMIDIFIER being installed in June. (Shop is 1000SF and Mitsubishi unit I'm installing has dedicated dehumidifying when AC and HEAT are not needed. Want to match the humidity with the internal level in the house to keep wood from moving when moved into the house from being built in the shop)
5. Boom Arm installation with California Air Compressor in the Attic for noise reduction. Air hoses feed to far walls and through the Boom Arm's Energy/Air box.
Machines....to add...
Selling my 3HP Sawstop PCS and purchasing a 5HP Sawstop ICS. Current TS has router table attached, and has Incra fence, positioner, and rails. New one will be TS only with Incra TS/LS Positioner.
Dedicated Router Table with under table DC and Incra Wonderfence Positioner.
Jet Oscillating Drum Sander 22-44
Probably a Grizzly 20" Floor mounted Disc Sander.
CNC Shark HD3
Current heavy iron already in the shop:
Hammer A3-41 with Silent Partner head
Laguna Italian 20" Bandsaw
Laguna 14"SUV Bandsaw
Delta 18-900L Drill Press
Powermatic "Mustard Monster" 3520B Lathe
Laguna REVO 10/16 Mini-Lathe
DeWalt DW788 Scroll Saw
SawStop 3HP PCS with attached Router Table driven by Porter Cable 7518 and Jessum Router Lift. (To be sold)
JDS 3HP Cyclone Dust Collector with Mobile dust drum.
JDS AirTech HP Air Filtration unit.
That's where I sit at the moment as I work towards completing my "Lifelong Woodshop". Working on it...IF I can keep off of FOG long enough to get some work done! [blink] When it's done, I'll have my ultimate shop and will feel good retiring in 10 years or so with something to do that I'm passionate about (also deep-sea fishing and photography), rather than sitting around waiting for the end!
Cheers,
Frank
