- Nov 18, 2010
mikeneron said:I guess I will be making these cabinets 23 3/4" deep :-[
Can you add 1/4" banding to save your 24"?
fritter63 said:erikfsn said:If I write down 13/16" or 15/16" I sometimes see 3/16" or 5/16", my mind drops the "1" and the result isn't pretty . . .
Why metric is better! [big grin]
fritter63 said:Why metric is better! [big grin]
joraft said:erikfsn said:If I write down 13/16" or 15/16" I sometimes see 3/16" or 5/16", my mind drops the "1" and the result isn't pretty . . .
The point is it's not as prone to misreading 21mm instead of 13/16" or 24mm instead of 15/16". [wink]
I don't know about yours, but the metric I use also has the "1", and dropping it by mistake cab be just as ugly. [smile]
RonWen said:The point is it's not as prone to misreading 21mm instead of 13/16" or 24mm instead of 15/16". [wink]
joraft said:RonWen said:The point is it's not as prone to misreading 21mm instead of 13/16" or 24mm instead of 15/16". [wink]
A fairer comparison would be reading 5/16 instead of 15/16, and reading 5mm instead of 15mm. In my opinion, both are just as easy to do.
As they say: Measure twice and cut once. [wink]
RonWen said:Similar to the average typist that makes an error every 300 keystrokes, the fewer digits the fewer errors.
joraft said:RonWen said:Similar to the average typist that makes an error every 300 keystrokes, the fewer digits the fewer errors.
Yep, and the best way to never make a mistake is to never do anything. [smile]
RonWen said:That explains so much... [big grin]
