10digit,
Great job all around - design, construction, finish and tutorial!  I think you are likely to draw many more compliments from those who see this project.
Thanks for the tips on moving the work-in-progress around the shop (mover's dolly) and how to make the unit mobile if access to the back is needed after final assembly in a room of the house (threaded stem casters with T-nuts).  Before reading of your approach, I was thinking of load levelers with a similar threaded shank that is configured to accept a hex key (Allen wrench) internally of rhe stem.  The bottoms of the load levlers could be equipped with those low friction glides since my unit is intended to be installed in a room with wall-to-wall carpet where small casters don't work very well.
One question regarding the water-based finish that you chose.  I have read that some WB finishes react with the tannic acid in oak causing discloration.  Did you take any steps to prevent this, or does the stain that you first applied act as a sealer against such reaction, or ir the General Finish brand product not reactive with oak?  (My entertainment center is being made of oak.)
sToolman,
Thanks for the reminder/tip/link to Gary Katz's tutorials on use of SketchUp.  I'll definitely look into them.  But I couldn't wait for my SketchUp skills to catch up to my hand drafting skills and my desire to get started cutting wood.  Tonight I cut all the oak plywood panels needed for the center unit and two bookcases to be positioned on the sides of the center unit.  I used my shopmade Guide Rail Side Stops to facilitate repeat cuts with my TS 55 and 3000 mm Guide Rail.   A simple way to achieve excellent repeatability of cut width.
If anyone else is considering building an entertainment center, I recommend they check out the latest issue  (Oct. 2008) of Fine Woodworking.  In that issue is an excellent article beginning on page 58 by Steve Casey describing how he designs and assembles a low console for a home theater.  He uses many loose biscuits for location of wood components together with screws to secure many of those components.  I plan to substitute Domino joints; I do not have a biscuit joiner.   Unfortunately for me, to achieve the visual effect my wife wants, I cannot use many of his construction ideas and techniques.
Dave R.
