Frank Pellow
- Jan 16, 2007
Some of us got off topic in the Home Made Sysports thread and started discussing traditional woodworking benches. I even received some valuable information there that helped me to make a decision about the bench that I just completed (thanks again butzla).
So I thought I would start a thread here about my bench. I just completed it a couple of days ago. Here are a couple of pictures:
[attachthumb=#1] [attachthumb=#2]
A few facts:
- Bench top made of hard maple (most of which I obtained free from a neighbour)
- Base cabinet made from Baltic birch plywood with maple trim and a little bit of MDF and hardboard
- The maple parts are finished with three hand-rubbed coats of polymerized Tung Oil and the plywood parts are finished with two coats of Spar Urethane
- I planned the bench myself ?with some inspiration from Shopnotes and from my friend Rick Thom
- It took just about a year of elapsed time to build
- Dimensions: 88 cm high by 60 cm wide by 165 cm long (that?s approximately 34.5 inches by 23.5 inches by 64 inches)
- Weight of the top: 68 kilos (or about 150 pounds)
- Weight of the base (when empty): 125 kilos (or about 275 pounds)
- The bench is mobile, which is very important to me in my small shop, but, when the castors are locked, it is very solid and stable
I covered the construction of this bench in two very long and picture filled threads on the Canadain Woodworking forum. The links there are:http://www.canadianwoodworking.com/forum/showthread.php?t=16233 andhttp://www.canadianwoodworking.com/forum/showthread.php?t=20893
You will see, if you glance at those threads, just how much I use all of my Festool tools on a typical project.
A few facts:
