Birdhunter
- Jun 16, 2012
I was putting together two of four 3/4” white oak panel sections using 8mm Dominos. I’ve jointed many panels using the Dominos for alignment. The reference surfaces have always ended up flush to the couch.
These were off just enough to be visible. I measured both side’s mortises and they seemed ok except the wide (I use narrow to wide mortises) mortises seemed a little loose.
I did the other two using a 6mm bit. Those two joined up perfect.
I have plugged up the mortises on the bad two panel sections and will try again later with the 6mm bit.
I measured all the boards and they are all within a few thousands of being 3/4”. They were jointed using the alternate slide to the fence method.
I’m totally mystified! Any ideas.
