GhostFist said:In all honesty, how often are you doing 45 degree levels in framing? Particularly in a cross cut?
GhostFist said:Hip and valley rafters are rarely if ever 45 degrees. It's besides the point however as these cuts are rarely made for most general construction. There are competitors saws in various sizes and ability, some are capable of 60 degree bevels, if it's a must for you.
Hips and valleys are always 45, unless it is a hexagon or some other shape. The pitch may vary but hip or valley rafters always need a 45. You will not pass a framing inspection otherwise.GhostFist said:Hip and valley rafters are rarely if ever 45 degrees. It's besides the point however as these cuts are rarely made for most general construction. There are competitors saws in various sizes and ability, some are capable of 60 degree bevels, if it's a must for you.
tjbnwi said:I'll make my decision on this purchase at Connect. All of my responses of the saw not making the cut are based on comments in this thread. Specs say it should work, we'll see.
Rick Christopherson said:tjbnwi said:I'll make my decision on this purchase at Connect. All of my responses of the saw not making the cut are based on comments in this thread. Specs say it should work, we'll see.
These comments are getting to the point of being much ado of nothing. I went down to the workshop and made a 45 degree cut in a 2x4 with the HKC55. It made the cut just fine, but left a small pointed sliver behind on the one side of the cut. The other side of the cut is completely through.
It's not exactly the type of saw I would expect someone to use for cutting hip rafters, when they historically slash a pencil line and cut it within +/- 1/8"
tjbnwi said:Maybe if you would have bothered to post earlier of your results some of the comments could have been avoid. According to Shane he had it on "good authority" the HC/HKC 55 would not cut through a 2x framing member at 45º. Seems that you must not be a "good authority".
Rick Christopherson said:tjbnwi said:Maybe if you would have bothered to post earlier of your results some of the comments could have been avoid. According to Shane he had it on "good authority" the HC/HKC 55 would not cut through a 2x framing member at 45º. Seems that you must not be a "good authority".
Ummmm, cuz it's not my job. [big grin] [big grin] [big grin] [big grin]
Actually, Shane shot me an email right after my posting. I was having a late lunch, but I've wiped the grease from my fingers and went down to the shop to take a picture of the cut.
I didn't do anything fancy or special with the cut. As a matter of fact, I had never even used the saw yet. I simply made the cut to find out how bad all the hype really was, and had no intention of taking pictures. But at Shane's request, I did.
The picture below shows both the offcut side (top) and the workpiece side (bottom--flipped over). As you can see, the blade did go all the way through the material at about the centerline of the kerf. It is only the inward bevel side that is a little shy of going all the way through.
Peter Halle said:Hey guys, let's not get this personal. Heck, Festool Connect is coming up at the end of the week and my guess is that Tom will see first hand if the saw will make the cut on the rail. I know that I will.
