rodwolfy said:I didn't like that tab either. Made it so that I couldn't put down a piece of flooring and do a rip cut down the middle. I had to put up the rail and they lay the flooring length wise w/ quick clamps to do a rip. Did an amazing job at dust collection and lack of chipping. Just what I bought it for!
If Festool were looking to improve the MFT, they should figure out some way to remove that tab. Either by having an insert that slides into the guide rail "T" and locks in place, which would in-turn lock into the lower plate, or some other method.
Cheers,
Rod
rodwolfy said:Eli,
The 1/2" collet doesn't come standard with the router??? Or do you mean the 1/2" bushing?
Rod
rodwolfy said:OK guys,
You all say to buy the extra quality hose. I take it you mean the Anti Static one. I saw several different ones. I get one with the vac, which will be connected to the boom arm. Some of you hook up a second hose with a "Y" connector, or do you just plug and play with whichever hose you need? Would this need a connector to go from 27mm to 36mm?
What I have always found with a vac hose, is get the longest one that I can. I saw that they have a D36x7M (#452886) which would fit the bill, but it doesn't come in the kit. Does Festool allow you to switch out the hoses and pay the differnece? Do you really think that the Aluminum Industrial Floor Nozzle is worth the extra money over the Plastic Tradesman Floor Nozzle which also includes the other nozzles? -
Do I need the Suction hose holder, SHR-CT/SR as someone mentioned in a different post?
AND, what about the router questions?
Thank you!
Rod
Eli said:rodwolfy said:I didn't like that tab either. Made it so that I couldn't put down a piece of flooring and do a rip cut down the middle. I had to put up the rail and they lay the flooring length wise w/ quick clamps to do a rip. Did an amazing job at dust collection and lack of chipping. Just what I bought it for!
Cheers,
Rod
It would be nice if that whole side just sid all the way below the surface of the table somehow.
