New Kapex KS60
I think the KS 60 would be Festool's answer to competitor Metabo who has introduced the KGSV 72 XACT SYM.
-click-
Peter Halle said:
antss said:
Yea, but will the 110v motor be any good ?
Perhaps a cordless version would be better from that standpoint.
And to counter your question - Will it even be available in 110V?
Seen some hints regarding a 110v version. See attachment.
To be honest, Festool would have to be bonkers not to develop this as 240, 110 and also cordless. The compact SCMS market must be huge.
-click-
My take on that comment is that the Metabo saw is exactly what Festool _should have_ gone for and that it is more "innovative" than the KS 60. I think the Metabo seems like a great saw and if I was in the market for that (blade) size saw I would probably go for it. And after seeing the footprint and cut capacity on the KS60 video I probably will go for the Metabo, when it is time to retire my small Makita LS0714.
I have the Festool SYM 70 E and I used to have the Kapex 120. I did find that I reached for my Makita LS0714 90% of the time and that it does a great job (except for dust extraction) and the Kapex sat idly for the most part.
In my head I was thinking that if Festool made a smaller sized Kapex with the SYM saw features incorporated it would be my "one and only" mitre saw. Metabo did just that with the KGSV 72 Xact SYM.
Hello everybody,
On a Dutch site the new kapex Is avalible 699 euro. And the specs are online to Kapex 60
Technische kenmerken
Opgenomen vermogen 1200 W
Onbelast toerental 1300 - 3500 min-1
Diameter zaagblad 216,00 mm
Zaagdiepte 90°/90° 305 x 60 mm
Zaagdiepte bij 45°/90° 215 x 60 mm
Hellingshoek 47/46 ° Verstekhoek 60/60 °
Afmetingen (LxDxH) 661 x 475 x 430 mm
Aansluiting stofafzuiging Ø 27/36 mm
Gewicht 17,80 kg
Zaagdiepte 60°/90° (rechts) 150 x 60 mm
Zaagdiepte 45°/45° (links) 215 x 40 mm
Zaagdiepte 45°/45° (rechts) 215 x 20 mm
Leveringsomvang
HW Universeel zaagblad W 36, schroefklemmen FSZ 120, bedieningsgereedschap, in doos
The price is acceptable don't you think?
ocram
I've spotted this machine on an exhibition in Belgium
There is a professional market for this size of saw in the UK for certain (and much of the EU as well). I use a 216mm (8-1/4in) DW saw as my general jobbing saw on lower cost installs for everything from framing to skirtings (baseboards) and wood flooring. They are small enough and light enough to lug about site - my Kapex KS120 isn't. If it has double bevel and really is compact then they may have a winner there. Time to start saving my pennies?
If the fence on that Metabo is anywhere near as accurate as Mafell's ERIKA, I don't even care what the mini-Kapex does. That thing looks awesome.
If anyone is interested we can get the Metabo saw right now for 855.68 shipped to anyone in USA, same for the KS60(near double that though).
We should be having a play with one of these soon. 8)
I'll report back but looks to be useful addition to the Armoury! [smile]
I look forward to that.  I'd also like to know if it will be compatible with the existing UG frame and extensions for the 120.
No, it doesn't look like they are compatible. The UG cart & extension wings are listed in the KS60 accessories as specific to the KS60.
.....they fit from the KS120......there are also specific legs for the KS60. I will post some pictures later this evening
Rg
Phil
....the KS60 fits via an adapter plate....cool piece of kit
Rg
Phil
Let me know, I want to come and play! Seriously, I'm wonderng if one would make a good replacemengt for my eWalt DW771 216mm SCMS
Hello
Will the kapex ks 60 cut a 2x6 (North American units) in one pass?  That is to say what is the travel of the cut at 90 degrees and 90 degrees?  The technical data suggest 6 cm of travel, a distance that seems especially short. Perhaps we can work around some this be raising the 2x6?
Come to think of the hk55 issue, wil the kapex ks 60 cut a 2x4 in one pass at either 45 degrees on the bevel or 45 degrees on the miter ?
^^ not sure I've ever used a mitre saw that can't do this. Looking at the pictures of the KS60 there is no doubt the saw can do those cuts!
Not sure if you were just making a joke based around all that HKC chat gone before. . .  [smile]
specs are clearly on site crosscuts 12" at 90 and 8.5' at 45. The spec that one should take notice of is 1200 watts, 10 amps at 120, not exactly over powered but we shall see.
