Heyas!
Ok, I did a search per forum etiquette. However, the search terms are a bit loose, so I didn't come up with anything.
I've got a 150/5 RO sander. I'm currently sanding down some varnish on my old Chris Craft boat. I'm using the 240 and 320 Brilliant sandpaper.
I'm also using a 3M 05777 sanding interface pad.
However, the 3M pad doesn't have the Festool hole pattern.
So, here's the question: Does Festool make a similar interface pad?
The reason I ask is that the vacuum system doesn't work nearly as well when the holes don't line up (as I'm sure you all know, but I thought I'd make obvious in case someone thought I just wanted to be cool with my hole lining abilities.)
