Wooden Skye
- Mar 6, 2012
Don T said:Would the vacuum pump be able to be used with vacuum bag?
I agree this becomes more attractive if you can use with vacuum bag for veneering.
jimbo51 said:What happens when the power to the pump is cut?
Does the workpiece immediately become free or is there some delay to allow the operator a bit of time to react? A sudden release of the workpiece could be exciting if the operator was a bit off balance.
I can certainly see where it would be very handy when using the Domino to have the wood sort of floating in the air and accessible without having to worry about bumping into clamps.
Consider just one simple example; putting edge banding around a panel. You start with the clamp positioned with the panel vertical in front of the table. After doing the first edge, you just spin the head 90 degrees to the next edge. Especially if you were applying continuous banding, where you would spin the head for each application edge, and then go through them again for trimming.Cheese said:bigred00 said:I'm pretty certain this product will suck.
I agree with you, just curious as to your thoughts...
prodriquez@msn.com said:Does anyone know if I can use my own vac pump?
grbmds said:[member=191]Rick Christopherson[/member] Beyond the circular clamp plate with the SE1 is there any need for an additional head, like either the small or larger oblong head in actual use?
Nat X said:How many inches of mercury does the pump pull?
I can't remember exactly what the setup was, but yes, there is a T-fitting and I believe an isolation valve too. It uses the single foot pedal and single feed line from the pump. The T-connection is made at the clamp head.copcarcollector said:On the $1800 set, 57000004, how are the two clamp heads connected to the vacuum pump?
Does this set include 2 vac hoses and/or "T" fittings or...? to 'power up' both clamps from the single vacuum pump? Do the 2 clamps daisy chain with each other on the vacuum line, or does each have to be connected directly to the vacuum pump?
Yes, I believe it does when mounted on the correct MFT/3. I took it off my main MFT/3 before even trying it, and re-mounted it to a smaller old-style MFT I have laying around. So mine won't fold up completely, but it still clears the top when I need to.copcarcollector said:Thanks Rick
Ref the mft mounting plate, when it swings under the table, does it lock in the 'stowed' position?
