festnoob
- Jun 13, 2010
Worm Drive said:Was the track clamped down?
If you were asking me, yes it was clamped.
elimelech12 said:It was tight on the rail for a perfect slide. I used the stock blade. I've had a 55eq, a 55req (prior to recall), and a 75 and never experienced a cut like this. Can't even use the rail until the strip is replaced. My saw was manufactured in 12/13...maybe the standards changed. Who knows?
Vanquish said:elimelech12 said:It was tight on the rail for a perfect slide. I used the stock blade. I've had a 55eq, a 55req (prior to recall), and a 75 and never experienced a cut like this. Can't even use the rail until the strip is replaced. My saw was manufactured in 12/13...maybe the standards changed. Who knows?
elimelech12, I just saw your original post and was wondering what the outcome was? Did you send the saw back and is it working properly now?
Oso Rojo said:Vanquish,
What was the outcome on the saw problem?
JimmyJames said:Hey guys, I recently purchased a TS 75. This is my first Festool product. I also noticed it was quite loud, with a vibration as well. Not nearly as smooth as my new DeWalt circ saw. At first I was scared to even use it, in case I needed to return it. I've since cut a walnut slab with it, but man, it is loud, and not a good tough, binford way. Is this really normal????
