squall_line said:Lincoln said:squall_line said:Bencan said:Ya I really wish they had made the saw where is could be locked in plunged so you can use it with the fsk rails. But no couldn’t possibly do something that would be helpful and improve functionality
The saw is fully compatible with and was demonstrated on an FSK rail. I don't understand this complaint.
You can't lock the blade depth, like you can with the HK/HKC.
I don't understand what that has to do with using the saw with the FSK rail, though. The saw is compatible with and was demonstrated on the FSK rail.
You said you didn't understand the complaint, I tried to explain it, as I see it.
It's compatible, but not exactly easy to plunge the saw, hold it at that depth, hold the rail, make sure it's pushed up to your material, make the cut without the rail and saw rocking, finish the cut and let the saw 'un plunge'. All the other crosscut saws have a depth lock feature - HK, Mafell, Metabo.
